It is currently Sat Jul 19, 2025 6:21 pm
PostPosted: Thu Jun 24, 2010 3:48 pm
Last Name: Charnock
Country: UK
Hi
Have any of you recently completed a Martin OM kit with plastic binding and end graft?.
I would like to see some pictures of the layout if you have any.
I am about to start the binding on my first guitar and I am not sure of the layout.
PostPosted: Thu Jun 24, 2010 4:01 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
hi John,
there have been many, many OM models over the years. but seriously, you are building your own guitar, make it anything you want.
if you want to copy a Martin model, the best thing I think that you could do is google image search "martin OM" or , ... "OM-18" ... "OM-21" ... etc, and copy one you like. there is no rule that says a Martin OM guitar kit has to look like a Martin OM guitar, though.
http://www.google.com/images?um=1&q=martin%20om
I built a Martin kit recently, and I tossed the plastic and used curly maple instead.
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Thu Jun 24, 2010 5:16 pm
Martin,
Here's an OM I finished early this year. It may not be exactly to Martin spec, but I think it's pretty close to what Martin does with their plastic bindings.
PostPosted: Fri Jun 25, 2010 12:43 am
Last Name: Charnock
Country: UK
Hi Pat
Thanks, it looks nice - what is the binding material ?
I have a length of plastic tortoiseshell binding and a length of black and white purfling for the top and a length of plastic tortoiseshell only for the back. They have supplied a plastic tortoiseshell end graft and two pieces of black and white purfling which I assume goes either side of the end graft. It was the layout I was interested in - I suppose anything goes really ?
PostPosted: Fri Jun 25, 2010 7:15 am
If you are looking for Martin OM binding pictures , go the their website , then look up OM's and you will see detail pictures. As for OM you have so many options . 15 series , 18 series , 21 series , 28 , 35 , 40 , 42 , 45 Lawrence Juber Eric Clapton , and the list continues .
PostPosted: Fri Jun 25, 2010 8:35 am
John,
The material is curly maple. The gold tone is from Behlen's Rockhard Tabletop Varnish.
The two short strips are indeed for the sides of the tail graft. I would orient them to have the white strip next to the darker material. For example, if the guitar had EIR back and sides, with maple binding, I'd put the white strip next to the EIR, providing the greatest contrast.
PostPosted: Fri Jun 25, 2010 8:37 am
Last Name: Charnock
Country: UK
Thanks Pat
I think I am getting there - just need soem glue now :P
PostPosted: Sat Jul 10, 2010 8:55 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
Not the best picture, but here's the Martin kit I built in 2009 with tortois bindings.
Chris.
PostPosted: Sun Jul 11, 2010 4:38 am
Last Name: Charnock
Country: UK
Hi Chris thanks
I managed to get the binding fitted, it wasn't that much of a problem as I first thought - I used the black and white edgingwhich you can just see in this photograph. It looks like you didn't use any on yours?
J
PostPosted: Sun Jul 11, 2010 5:59 am
Last Name: Wood
State: PA
Nope, no additional purfling on mine. Yours looks great, nice work. I found the plastic binding easy to work with.
PostPosted: Sun Jul 11, 2010 6:32 am
Last Name: Charnock
Country: UK
Hi Chris
Thanks, I would definitely use it again. This was a kit so I wanted to stick to the plan, the plastic tortoiseshell looks quite good.
I manged to get some weld-on cement which formed a skin very quickly, you need three hands for binding !
I also used a hair dryer to remove the tape I used to hold the binding in place. This caused the binding to expand and lift, i was going to re glue but by the time it cooled off it had re shrunk back to the wood.
